How do I get the CAM Bolt off?
On the SOHC, there are two 8mm bolts under the gear that hold the inner cover to the head. Grab an 8mm 1/4"-drive socket and put it on a screwdriver-type handle. You're going to use this for leverage to keep the gear from turning. Also grab an 18mm socket for the cam gear bolt. See the pic below. It's tight, pull hard! Remove that 18mm bolt and the gear slides right off by hand.
Info courtesy of JeffB#2.
impact wrench will work great, but you can also hold the gear still with a pair of channel locks or wrap the belt around the gear and hold it while loosening the bolt
Thanks for the replies. An impact wrench and an air ratchet are a necessity when doing this work. Ironically, I removed the one 8mm bolt I could have used to hold the wheel steady. I didn't even think of that when I was doing it. It sounds like the strap wrench and impact will work though.
