Stock motor+ turbo=?
RE: Stock motor+ turbo=?
ORIGINAL: spudsterier
the hahn turbo kit runs about $2500.00
i just sold a hahn turbo and manifold on eaby the other day for $300.00, so it is a little easier to piece one together
if you use the dohc you can just get a map clamp.....
also, Spudsterier, what are you doing for fuel?
the dohc head on the sohc block will lower your compression.....lower compression = higher boost capabilities
my fuel system now consists of 2 walbro 255lph fuel pumps....1 intank and 1 external, a begi rrfpr, and some 30lb. accel injectors.....should be any problems with too little fuel
my car is currently out of service.....i was running 8-9psi of boost on a completely stock dohc motor with 150,000 miles.....the motot lasted 10,000 miles until i spun a bearing....now i have JE pistons, eagle rods and a few other things to go on the motor as soon as it gets into the machine shop....
so i would hihgly reccommend building the motor a little before putting boost to it if you plan on it lasting at all
ORIGINAL: das2123
No link, but I can get a hold of the guy for you.
ORIGINAL: JoKeR6
have a link to the plate maybe?
ORIGINAL: FastNeon84
i heard of those those crank scrapers....what exactly do they do Das?
http://www.modernperformance.com/dcx...scrapers.shtml
