engine chugs on startup and runs like ****!
Old Mar 13, 2007 | 04:48 PM
micahman's Avatar
micahman
Default RE: engine chugs on startup and runs like ****!
also after i have been driving it for a while or for a long period of time, if i turn the car off it will start right back up and half the time it wont chug or run like **** or half the time it will chug untill i hit the pedal a bit.
Old Mar 14, 2007 | 04:34 AM
Newneonguy's Avatar
Newneonguy
my car just did this tonight. Ran fine after sitting for an hour. bad gas? water in the tank? who knows, I think certain neons are possesed.
Old Jul 26, 2007 | 06:54 PM
idrivejunkcars's Avatar
idrivejunkcars
I just had the same problem with code 43 set and the car lack of power. Found it was the fuel regulator that sets ontop of the fuel pump. it's called the fuel regulator/filter. five minute fix
Old Oct 27, 2007 | 01:21 AM
dodgeneonguy's Avatar
dodgeneonguy
[align=left]so, i have a 95 sohc neon, i have two cyclenders, that arent firing where they should be, the problem cyclenders are numbers 1 and 4, cyclender 4 is a striaght up dead miss, number one, just is firing realy crappy. i have cleaned the fuel rail, changed the ignition coil pack, new spark plugs and spark plugs wires, and the problem still persissts, and the trouble code it displays is 43, so i was wondering on possible causes, and ways to fix them.
[/align]
Old Oct 27, 2007 | 12:59 PM
tattoojack's Avatar
tattoojack
ORIGINAL: idrivejunkcars
if that was bad wouldnt it do this all the time? i am leaning towards cleaning my IAC since once it gets hot it runs great. sounds like the goo clears out enuf to run right once warm and the settles back over the IAC once it cools.
