codes
Old Mar 12, 2007 | 11:31 PM
jnd2970's Avatar
jnd2970
Default codes
could someone please take a moment and explain, or point me in the direction of how to get a code sheet for a 1996 neon. I do not understand how to retrieve them or understand them. Please help.
Old Mar 12, 2007 | 11:50 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: codes
put the key in the ignition, turn to the on position and then off like 3 times. so on off on off on off on. then you will see the check engine light flash. when it pauses for a short while (maybe 5 seconds) then it will go to another number (flash pause flash flash = 12). when it pauses for longer than its moving onto the next code. when you see "flash flash flash flash flash pause flash flash flash flash flash" then its 55 and that means that there aren't any more codes.
http://www.techknowman.com/Dodge%20N...dge%20Neon.htm
there you can get what the codes stand for...near the bottom
Old Mar 13, 2007 | 12:06 AM
jnd2970's Avatar
jnd2970
Default RE: codes
Thanks
Old Mar 13, 2007 | 01:23 AM
das2123's Avatar
das2123
Default RE: codes
In the 1st Gen FAQ's up top as well.
