A Little Help
Old Mar 14, 2007 | 05:18 PM
monsterstang's Avatar
monsterstang
Default A Little Help
Ok here is what is happening a friend of mine has a neon of coarse and its acting up he said if he don't let it set for like a half an hour when started it will die here and there when you drive it and he is just wondering what might be causing it to do that any help would be greatly appreciated
Old Mar 14, 2007 | 06:26 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: A Little Help
maybe timing bad fuel have him check it for codes using the key method
Old Mar 15, 2007 | 04:21 PM
monsterstang
Well the garage told him it was the mas air sensor and he just wanted to be sure before he replaced it
Old Mar 15, 2007 | 05:18 PM
das2123's Avatar
das2123
Did they mean MAP sensor? Neon's don't have a MAF sensor!
Is his CEL on?
And what exactly is the problem? Your post is a little difficult to understand.
