clutch?!?
Old Mar 16, 2007 | 08:55 PM
Leonheart17240's Avatar
Leonheart17240
Default clutch?!?
anyone know where to get a good clutch??? and how to tell if you need a modular or non? i m doing a swap soon and need a new clutch
Old Mar 16, 2007 | 10:02 PM
das2123's Avatar
das2123
Default RE: clutch?!?
Get the PT clutch. Stronger than the stock neon one.
95's and Mexico built neons got the non-modular clutches.
Old Mar 16, 2007 | 10:27 PM
Leonheart17240
you know and where to get astage one clutch?
Old Mar 17, 2007 | 12:30 AM
spudsterier's Avatar
spudsterier
modern performance
Old Mar 17, 2007 | 01:36 AM
Leonheart17240
ok so how do you know if its monular or non? or can you just put a modular one in??
Old Mar 17, 2007 | 03:15 AM
das2123's Avatar
das2123
Why do you need a Stage 1 clutch and what year neon do you have?
Old Mar 17, 2007 | 09:00 AM
racerx55's Avatar
racerx55
take your inspection sheild off behind the oil pan on the bottom , if it has an automatic flex plate and looks like a torque conveter boltd on, its a modular
[IMG]local://upfiles/37714/4D96289C908C4CD8BC98F0F15EEFC6DA.jpg[/IMG]
[IMG]local://upfiles/37714/286F09B5CBDE463ABC1C108333D4ECC4.jpg[/IMG]
Old Mar 17, 2007 | 11:41 AM
spudsterier
the modular is all one piece the non modular is made of separate components...
if your gonna rip out your trans and look from there, the non modular had about 6-10mm bolts around the outside rim on the front pressure plate.....modular has no bolts
Old Mar 17, 2007 | 03:12 PM
Leonheart17240
im going turbo, so stage 1 would be a good idea, and i dont have the trans on hand to look... still in other car.
Old Mar 18, 2007 | 01:43 AM
Leonheart17240
how do you know if it was built in mexico?
