brake issue
Old Mar 20, 2007 | 09:20 PM
mayjen's Avatar
mayjen
Default brake issue
I havea 98 neon and my brake lights stay lit at all times. I can only get them to turn off after I shut the car off and tap the pedal. Anyone with some do-it-yourself info?
Old Mar 20, 2007 | 09:32 PM
BadBrads97Neon's Avatar
BadBrads97Neon
Default RE: brake issue
Make sure the pedals are lubed on the back side. Like make sure they arent really dry because that makes them stick and stay and thats why the lights are on. I had that same problem on my 97 Neon and my step dad told me to just put some lube on the linkage thing on the back of the brake pedal and just push down a few times and it kept it from sticking. Just make sure the pedal is lubricated. Anyone else with some ideas?
Old Mar 20, 2007 | 09:36 PM
mayjen's Avatar
mayjen
I WD-40'd the back side of the box above the pedal (I think that's where the switch is) and stepped on the brakes a few times. It's still doing the same thing though.
Old Mar 20, 2007 | 09:44 PM
BadBrads97Neon
can you get them off if the car is on and you tap the pedals? Like you say they go off after you tap the pedals when the car is off. Try taping the pedals when the car is on and if they go off then its just something is sticking in the pedal if the dont and only go off when the car is off then it might be a fuse or something.
Old Mar 20, 2007 | 09:46 PM
mayjen's Avatar
mayjen
Hmm, I'll have to check my fuses then cause they won't turn off if the car is running.Need to get this fixed, sick of almost getting rear-ended. Thanks
Old Mar 20, 2007 | 09:59 PM
BadBrads97Neon
Ok I just did a little research to check on the fuses. If it is a fuse you would want to check and/or replace the 15 Amp fuse in the fuse block under the hood behind the battery. It is probably just marked "turn signal". Try that and see what happens. That is the fuse for the brake lights so that might fix your problem.
