still lost
Old Mar 24, 2007 | 06:24 PM
racerx55's Avatar
racerx55
Default RE: still lost
ORIGINAL: das2123
ORIGINAL: spudsterier
the dealership is the only place that carries the filter for 96-99 neons.....
Autozone shows they carry one for the 96 for about $20. Don't see why it couldn't be used in the 98. Does SOHC or DOHC matter spud?
the difference is steel or plastic tank, 96 came with a steel tank in the early models like the 95's, and its $20 external filter, after that theyre all plastic tanks and the filter is internal.
Old Mar 24, 2007 | 06:26 PM
mmench's Avatar
mmench
well i have tried that before on ths cluster and it didnt work . however i just took it out again and resoldered a second time. i also pinched the four little clips on the outward side of the curcit board. the four clips that touch the four prongds that stick like and inch off the back of the spedo motor. i drove it around the drive way and it seemed to work. maybe you can add that to the repair FAQ. well thats one problem solved and i just gota figure out the motor . thnx for your help
Old Mar 25, 2007 | 12:25 AM
spudsterier's Avatar
spudsterier
dohc and sohc dont matter
but racerx is right....however, the filter isnt exactly internal.....its on the outside top of the pump module
das, did you try to check and find one for a 98 neon?????
Old Mar 25, 2007 | 02:12 AM
das2123's Avatar
das2123
Didn't find one for a 98...just my 96.
Old Mar 25, 2007 | 02:35 PM
spudsterier
and there ya go
