SOHC to DOHC!?!?!
Old Mar 23, 2007 | 08:56 PM
neon527's Avatar
neon527
Default SOHC to DOHC!?!?!
i gotta a 97 SOHC ATX soon to be an MTX............is it true that all i need to do the SOHC TO DOHC swap is get......
DOHCpistons
DOHC head
DOHC valve cover gasket
DOHC head gasket set
DOHC headers
DOHC timing belt
if anymore input or less items it would be much appreciated!!!
Old Mar 23, 2007 | 11:45 PM
spudsterier's Avatar
spudsterier
Default RE: SOHC to DOHC!?!?!
first off.....header or manifold....not headers....there is only 1
second...you also need the intake manfold, passenger side motor mount, egr tube, pcm, valve cover, idler pulleys, timing belt covers, and possibly the wiring harness
Old Mar 24, 2007 | 02:06 AM
das2123's Avatar
das2123
https://dodgeforum.com/m_599520/tm.htm
Old Mar 24, 2007 | 03:03 PM
FastNeon84's Avatar
FastNeon84
sorry to butt in but do you use the pcm that matches the year of your car, or the head?
Old Mar 24, 2007 | 03:51 PM
das2123's Avatar
das2123
Year of the engine/block/head basically.
