wiring
im wanting to put switches in my neon so like when u get in turn the key or just leave it in ,
switch : 1 power
2 fuel pump
3 acces
and then hit the ignition switch vroooom
so what color is lets see: 12 v constant, accessory, and fuel pump and are they all in the ignition harness
also can someone tell me how to install a push button starter
thankx
switch : 1 power
2 fuel pump
3 acces
thankx
yeah i saw that but i want to do it all by switches, like leave the key in the ignition, and put a custom shield over the whole column so no one know the key is in there. but if i keep the key in run the
a radio
b door chime
c gauges
and fuel pump stays primed which proly isnt good all the time.
so i need to some switches to disconnect and i don wanna just use a battery disconnect
also how do i put in a battery disconnect without deleting my sterio presets and time.
a radio
b door chime
c gauges
