parts list for a 98 neon dohc
Old Mar 27, 2007 | 12:13 AM
yakima valleyrcracer's Avatar
Default parts list for a 98 neon dohc
aem cold air intake, msd ignition, msd coil, apexi turbo timer, moroso oil pan, solid bobble strut, indy head, aem cam sprocket, crower cam stage 3, venom fuel rail je pistons 8.8:1, eagle connecting rods, msd spark plug wires, hahn racecraft 20g turbo, quaife limited slip diff, clutch master ultra high clutch, b&m short throw shifter, booger bushing, kirk racing header, cr radiator, mopar perforamance pcm, at first then switch to a aem engine management system. does that sound alright to anybody if not what could i change
Old Mar 27, 2007 | 12:36 AM
rtneon67's Avatar
rtneon67
Default RE: parts list for a 98 neon dohc
if your goign turbo then why do u need the kirk header and if u are turboing u dont want to use a mopar performance comp
Old Mar 27, 2007 | 12:55 AM
das2123's Avatar
das2123
ORIGINAL: yakima valleyrcracer
kirk racing header, mopar perforamance pcm
If you are going turbo, then you won't need to get these.
You ready to drop $2000 on a fuel system??
Old Mar 27, 2007 | 02:25 AM
BadBrads97Neon's Avatar
BadBrads97Neon
Its his money lol
Old Mar 27, 2007 | 10:27 AM
spudsterier's Avatar
spudsterier
and if your gonna turbo then dont waste the money on the aem intake either
Old Mar 27, 2007 | 11:27 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
Especially give the fact that it isn't a true CAI anyways.
Old Mar 27, 2007 | 04:26 PM
spudsterier
though if you get a turbo then you dont actually need a true cold air intake since the air gets so much hotter when its goin through the turbo
Old Mar 27, 2007 | 06:51 PM
BadBrads97Neon
true true
Old Mar 27, 2007 | 11:33 PM
FastNeon84's Avatar
FastNeon84
ORIGINAL: BadBrads97Neon
Its his money lol
we'd rather him spend it the right way when it comes to a neon....
but dont forget about the machine work that needs to be done to the block....clean, bore and hone, balance and assemble, polishing the crank....would probably cost you another $400-$600
Old Mar 28, 2007 | 08:28 PM
what intake manifold would i use i'm thinking of indy intake manifold, a indy cylinder head does anybody know if indy is any good. and i dont want a loud blow off valve so what one would you guys prefere turbo xs or a greddy blow off valve. Thanks for all of your info i really appreciate it. well what im doing is a sohc swap to a dohc and i need a pcm first and thats why i put the mopar pcm in the list cause the turbo is coming later. sorry about that.
