timing belt?
Old Mar 27, 2007 | 09:11 PM
jewells3404's Avatar
jewells3404
Default timing belt?
Ok so i took my car to NTB to get an oil changed and i also told them that i thought that i had a belt loose because it makes this ridiculous noise when i start it well i'm thinking that its my A/C and powersteering belt but then when they called me and gave me this crazy price saying including the oil change and parts that it would come up toalomst $300so i'm assuming they meant my timing belt too? Well money is kind of thight right now so how do i know that they're not lying to me just beacuse i'm a young girl? how can you tell if there are problems with your timing belt?
Old Mar 27, 2007 | 11:29 PM
FastNeon84's Avatar
FastNeon84
Default RE: timing belt?
naw the timing belt is a completely diffrent belt....to do that u would need to change the water pump too....so that job alone could cost around $300-$400...if you were to take it to a mechanic.....
what exactly did they tell that they were gonna replace/repair for $300???
Old Mar 27, 2007 | 11:58 PM
jewells3404
I can't remember what belts they said i know one of them was the powersteeringbut i can't remember the other one i know that they said one was$39.99 and the other was $24.99. Well before I took my car there i looked online to see how much belts tyupically cost and i looked at autozone and other placesand they're relatively cheap. NTB has very expensive prices I know my friend got a battery there for over $100 then found the same one somewhere else for alot cheaper. I hate going into palces and them trying to rip me off justcuz i'm a young girl. They said the total was goign tobe $286 and I called my lil bro to get his opinion and he told me that was way too much
Old Mar 28, 2007 | 12:04 AM
FastNeon84's Avatar
FastNeon84
yea...thats waytoo much if its ps/ac belts they are just replacing, and the oil change....u should take it somewhere else
Old Mar 28, 2007 | 12:26 AM
das2123's Avatar
das2123
Go somewhere else.
Old Mar 28, 2007 | 12:32 AM
jewells3404
Yeah I plan on going somewhere else I want a new car but i'm 20 and this neon is my 5th car would the a/c belt have anythign to do with why my heat and my ac don't work i know my heatercore isn't leaking (i've already had that problem) i'm thinking maybe it has an air pocket in it cuz thats happened to me b4
Old Mar 28, 2007 | 12:35 AM
das2123's Avatar
das2123
If the belt is slipping then it would not turn the A/C compressor therefore you wouldn't get any cold air. Heat is a different issue though.
Old Mar 28, 2007 | 05:42 AM
kris95neonspt's Avatar
kris95neonspt
Man i knew the price of oil went up but damnI didn't think that much lol $300 is way to much there just trying to rip you offAnother way to tell if your a/c belt is slipping real bad is your power steering will cut out well atleast mine did.
Old Mar 28, 2007 | 06:18 AM
BadBrads97Neon's Avatar
BadBrads97Neon
yeah please take it somewhere else. that is way too much for just that stuff lol
Old Mar 28, 2007 | 09:33 AM
moretodo's Avatar
moretodo
The only thing that I can say is that my water pump just went out, I did not want too replace it my self so I called the dealer for fun, labor only was 298.00, the pump was 65.00 and the belt was 56.00 I told them thanks but no thanks so I'm going to rebuild one that I have sitting on the floor, have all the parts too do it anyway.
