1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
2006 Dodge Ram 1500
Old Oct 28, 2011 | 07:05 PM
chatty01's Avatar
chatty01
Default 2006 Dodge Ram 1500
I need help with the codes PO700 and PO750 ?
Old Oct 29, 2011 | 06:38 AM
SEAL's Avatar
SEAL
First of all you may get more help if you post in the correct forum. This is 1st Gen and you need 3rd Gen.
https://dodgeforum.com/forum/3rd-gen-ram-65/
You have a low reverse circuit code, and the most likely cause is the shift solenoid which is also called a solenoid pack.
Below is a tranny recall for your vehicle just for your info.
http://www.AboutAutomobile.com/TSB/2...+Unit+and+Line
