1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
brake and turn lights will not light
Old Feb 16, 2012 | 09:39 AM
rogerdog's Avatar
rogerdog
Default brake and turn lights will not light
replaced brake relay and multi-function switch unit with no results! where do i go next.
Old Feb 16, 2012 | 09:45 AM
crazzywolfie's Avatar
crazzywolfie
do the hazzard lights work? do the running lights work? did you test for power at the fuses? have you checked the ground connection at the lights?
Old Feb 17, 2012 | 08:44 AM
rogerdog's Avatar
rogerdog
Default lights
hazard and turn lights flash at dash board not exterior.
Old Feb 17, 2012 | 09:17 AM
rogerdog's Avatar
rogerdog
Default lights
running lights work.
Old Feb 17, 2012 | 10:10 AM
SEAL's Avatar
SEAL
What year is the truck? Did this just start and how long have you had the truck? Do you have power in and out of the brake switch? Have you pulled the bulbs and checked for power and ground at the socket? This is three totally separate systems. They don't share fuses or flashers or fusible links. I believe you will find the fault in the trucks ground system.
Old Feb 20, 2012 | 11:51 AM
rogerdog's Avatar
rogerdog
05 1500 would do it intermittenly for a year. one rear blinker started working. shifter won`t will not unlock now.
Old Feb 20, 2012 | 12:08 PM
SEAL's Avatar
SEAL
You might get more help at the 3rd Gen forum. It still sounds like an intermittent ground problem.
https://dodgeforum.com/forum/3rd-gen...iscussion-147/
