1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
1990 w250 Ramcharger stalls when breaking to turn
Old Aug 25, 2012 | 09:40 AM
cduffy's Avatar
cduffy
Default 1990 w250 Ramcharger stalls when breaking to turn
I have a 1990 dodge w250 ramcharger 4x4. when i am going to make a turn and apply the brakes it stalls. any ideas on what trhis could be. i just replaced the idle air control motor.
Old Aug 25, 2012 | 01:23 PM
Comrade General's Avatar
Comrade General
Hows acceleration? Do you feel any lose of power?
Check your ignition wire for grounding.
Old Aug 25, 2012 | 01:58 PM
sls001's Avatar
sls001
Have you checked the codes, fuel pressure, for vacuum leaks, and checked for loose or corroded connections at the battery, various grounds, and computer?
Old Aug 26, 2012 | 08:56 AM
cduffy's Avatar
cduffy
Default no just stalling when turning
acceleration is good. it seems to be when i apply the brakes that it stalls. it doesn't matter if i am turning or going straight. if i touch the brakes a little to hard it stalls
Old Aug 26, 2012 | 09:51 AM
SEAL's Avatar
SEAL
Was the replacement of the IAC in response to this problem or did this stalling start after the IAC replacement?
Old Aug 26, 2012 | 04:00 PM
cduffy's Avatar
cduffy
the stalling started before the IAC was replaced
Old Sep 5, 2012 | 01:29 AM
SixGun's Avatar
SixGun
Did you play with the idle speed? Before I knew better, I played with mine and it caused some stalling out. There's a procedure to setting the idle speed that includes a tach and an FSM for the proper procedure.
Old Sep 10, 2012 | 05:47 PM
Sniper X's Avatar
Sniper X
Same thing happened to my Range Rover after I set the idle UP once. at every stop light if I had to get on the brakes harder than normal it would stall. Set the idl;e back to normal, stalling stopped.
