1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
95 dakota lights
Old Nov 30, 2012 | 11:56 PM
roberthd69's Avatar
roberthd69
Smile 95 dakota lights
my 95 dakota lights go off sometimes when driving changed light switch no luck anyone no how to fix pls
Old Nov 30, 2012 | 11:59 PM
crazzywolfie's Avatar
crazzywolfie
you need to be more specific. what light? is it just the headlights or do all the lights go out?
Old Dec 1, 2012 | 12:05 AM
roberthd69's Avatar
roberthd69
Default just the headlights
thank you for reply its just the headlights
Old Dec 1, 2012 | 12:10 AM
roberthd69's Avatar
roberthd69
Old Dec 1, 2012 | 12:24 AM
crazzywolfie
do the high beams work?
Old Dec 2, 2012 | 12:01 AM
roberthd69's Avatar
roberthd69
Default yes
yes high beams work but the same happens wether in high or low
Old Dec 2, 2012 | 12:32 AM
crazzywolfie
so does shutting the lights off and then back on seem to fix the problem? i think there is a circuit breaker in the headlight switch and for some reason your lights keep tripping it. do you have aftermarket headlight bulbs?
Old Dec 5, 2012 | 11:56 PM
roberthd69's Avatar
roberthd69
No there stock lights
Old Dec 6, 2012 | 06:27 AM
SEAL's Avatar
SEAL
Have you checked the light sockets and wiring for corrosion or breaks? Wire wiggling seems to work well for checking for broken/corroded wires which are common problems in older vehicles.
