My Perpetual 76 Project Thread
#145
#146
no. the float bowl has a vent tho. it should not cause a vacuum leak.
when adjusting the idle mixture screws you adjust the left and right mixture screws equally until you can get it to idle as high as possible. then you adjust the throttle stop screw to make the truck idle where you would like.
#147
Blast.
I need to figure out where it's leaking. I'm pretty sure I've got a vacuum leak SOMEWHERE. I just can't figure out where. It still stumbles a bit with the vacuum advance disconnected, or hooked to straight manifold.
GAAHHH.
I am kind of hoping maybe I can fatten up the idle a smidge and eliminate the stumble. Am I partially correct?
GAAHHH.
#148
this is were it would be nice if you had a vacuum gauge. it might help verify that you have a vacuum leak. with how few vacuum lines there should be on your truck it should easy to check. does it seem to idle fine? if so then you may not have a vacuum leak. could possibly have a bad accelerator pump. i would probably get the truck up to operating temp and then try adjusting the idle mixture screws until it idle as high as you can get it to then see if things run better.
#149
#150
