1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
My Perpetual 76 Project Thread
Old Dec 13, 2012 | 08:15 PM
  #21
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
What does the relay do in this case though?
Old Dec 13, 2012 | 08:21 PM
  #22
crazzywolfie's Avatar
crazzywolfie
that is the starter relay.
Old Dec 13, 2012 | 08:29 PM
  #23
dodge dude94
So even though it's a relay, if the alt decides to flake out, it will still allow stuff to blow up? How is the voltage regulator tied in with the directly wired alt.?
Old Dec 13, 2012 | 08:35 PM
  #24
crazzywolfie
but the relay does not control power flow into the cab. it controls power to the starter solenoid. you would be tying the alternator to the same connector as the battery wire/ wire that runs into the cab.
Old Dec 13, 2012 | 08:36 PM
  #25
dodge dude94
Okay, so it would flow right through the battery and smoke anything in the cab?
Old Dec 13, 2012 | 08:41 PM
  #26
crazzywolfie
it could fry anything before the fuses panel. the fuse pan should stop it from going any farther but the fuse panel is pretty far into the electric system.
Old Dec 13, 2012 | 08:43 PM
  #27
dodge dude94
So I pretty much need fusible links if I don't want to chance the fact of the truck burning down?
Also, when you run the new wire to the starter relay, the old one is just set aside, right?
Old Dec 13, 2012 | 08:50 PM
  #28
crazzywolfie
you got it. i think you could just leave the old wiring connected. this would just bypass all the weak electrical. you could even just run the wire to the battery terminal if there is room.
Old Dec 13, 2012 | 08:52 PM
  #29
dodge dude94
Leave the old wire connected on the alt.? Wouldn't that still, in theory, allow current to pass through that old wire?
As for running it to the battery, I just might do that, there is plenty of room up there.
Old Dec 13, 2012 | 09:03 PM
  #30
crazzywolfie
but it would still take the stress off the old wiring allowing power to flow straight from the alternator to the battering instead of having to flow through the bulkhead connectors. chrysler was well aware of the problem - in fact, police, taxi, and fleet vehicles, whose electrical loads were typically quite high (and which vehicles typically had a “fatter” alternator) had the two charging-circuit conductors removed from the bulkhead connector, and its woefully-inadequate 1/4-inch Sta-Kon connectors, and run directly through the firewall (with a simple rubber grommet)
