1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
Oil capacity for a 5.2?
Old Oct 14, 2022 | 12:35 PM
tjco's Avatar
tjco
Default Oil capacity for a 5.2?
I’m doing an oil change on my truck, looked up the capacity and the website I found says 5 quarts. I drained it and put about 3.5 quarts in and let it sit for a couple minutes before I checked the dipstick. The oil comes right up to the very top of the safe line as if it’s at max capacity. Do I have the wrong dipstick or something? I don’t want to ignore it and go dump the other 1.5qt in and blow all my seals out but 3.5qts for the engine and filter just doesn’t seem right.
Old Oct 14, 2022 | 01:42 PM
crazzywolfie's Avatar
crazzywolfie
i have never put less than 5 quarts in a 5.2 especially if it leaks. usually put about 5.5-6 depending on how bad the rear main and valve seals are.
Old Oct 14, 2022 | 05:30 PM
tjco's Avatar
tjco
welp i guess I’ll just throw the rest in there and see what happens then. Idk if I have the wrong dipstick or what but she definitely appears to be overfilled already.
Old Oct 15, 2022 | 09:32 AM
Machomur's Avatar
Machomur
Did you run the engine to fill the filter?
