burnt wire harness
Old Apr 22, 2007 | 07:11 PM
keglined's Avatar
keglined
Default burnt wire harness
I need a complete wire harness for a D250 slant six 1985. The wires caught on fire and burnt mostly on the firewall side small box on wheel wellwith about 4 wires coming from it by the battery looks to be the hot spot. Any help where to buy one???
Old Apr 29, 2007 | 05:01 AM
Chump's Avatar
Chump
Default RE: burnt wire harness
ORIGINAL: keglined
Might try www.car-parts.com or www.junkyarddog.com
Old Jun 18, 2007 | 05:07 AM
patricklyle77's Avatar
patricklyle77
I have had the identical prob. plus some. that "box" is a relay. junkyard item. check and replace all fusible links going to the firewall block. if you have a bad one and don't fix it, you'll catch the harness going to the steering column on fire like i did! that harness starting from the battery is the electrical lifeline of the truck, and are notorious for going up in smoke on older dodge trucks. good luck!
