'85 dodge power ram idlein' problems, help
Old May 23, 2007 | 01:00 AM
Ramt0ugh85's Avatar
Ramt0ugh85
Default '85 dodge power ram idlein' problems, help
Hey fellas. I got this Dodge Power Ram 250. Im tryin to fix it up for a local sport show thing, but I gotta start from the ground up. When you start the truck, and stay in park (its a automatic) It Idles extremely low. Sometimes to the point that it shuts off completely. Im thinkin its the carb. Any ideas?
Old Jun 18, 2007 | 09:08 PM
HellaciousHemi's Avatar
HellaciousHemi
Default RE: '85 dodge power ram idlein' problems, help
It can be the carb, try starting it with the hood open so you can go under there n see whats happening as soon as its started. For starting out go buy some carb cleaner preferrably Amsoil Powerfoam, I myself have used that on my truck which isinjectionand some customer cars I have done tune ups on. Go that route first and the canof Powerfoamis not expensive. When you spray it spray it right down the carb (both sides)little by little until it almost diesthen as it returns to idle you spray more n so on. After you have been spraying for little whilelengthen the spraying time untilthe truck seems to be dying again etc etc. Use the whole can of it, this won't just clean your carb it will be cleaning you intake manifold and probably little of the valves also.
Old Jun 20, 2007 | 07:59 PM
Maui_808's Avatar
Maui_808
better yet, just take the whole carb off, soak it, take it appart clean it.
