Whiper not working
Old May 26, 2007 | 07:57 PM
bobziol's Avatar
bobziol
Default Whiper not working
Restoringa '84 Ram 100 Custom that needs to energize the Whiper motor. No voltage on motor or control switch. Fuses are ok and I don't know if switch grounds or supplies voltage to motor. Can't seem to find wiring diagram for this area. Any suggestions. Thanks Bobz heavenly@695online.com
Old May 28, 2007 | 06:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Whiper not working
You may have a blown fuseable link on the drive side under the hood.
Old Jun 11, 2007 | 01:30 PM
bobziol's Avatar
bobziol
Thanks, Will look at them.
Old Jul 24, 2007 | 10:00 PM
dman782's Avatar
dman782
i had to run a ground from one of the screws on the motor to the firewall now mine work all the time.i figured that out by accident i had the key and the switch on when i pulled the motor out to replace it and it bumped the air cleaner and started running so i put a ground wire on it and havent had any problems since.
