Fuel Injectors Question
Old Jun 10, 2007 | 02:19 AM
LT102's Avatar
LT102
Default Fuel Injectors Question
Can fuel injectors test ok electronically and still not be working correctly mechanically??
Old Jun 10, 2007 | 12:08 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: Fuel Injectors Question
yep all they are is an electro mechanical plung so to speak.
Old Jun 10, 2007 | 12:43 PM
LT102's Avatar
LT102
How can you check the mechanical to see if they area functioning correctly. My 92' D150 has developed a nastyintermitent miss. The last shop I had it to said they checked everything and still could not find the problem. I have used them many times in the past and found them to be very competent so I don't doubt what they say. The only thing they found wrong was it was "running a little rich", but the injectors electricly checked out ok.
Old Jun 11, 2007 | 02:19 PM
kurts2's Avatar
kurts2
Most people either try and clen them or just replace them. Some shops have a cleaner that they run through the system by itself (with no fuel). Stop by a local auto parts store and see what they have on their shelf and recomend, it's the cheapest way to go.
