need long wheel studs
Old Sep 23, 2007 | 09:39 PM
Madmurdok's Avatar
Madmurdok
Default need long wheel studs
Hi all! I am attempting to install aluminum wheels on my 1992 Dodge 3/4 ton, 4wd w Cummins. I need to find some longer than stock wheel studs. I have checked the local auto parts stores, and come up with something only slightly longer. I am sure I am not the 1st one to want to put new wheels on this year truck. Looking for any advice as where to find these studs. Already called Summit Racing - nothing.
Thanks!
Tim
Old Sep 26, 2007 | 08:22 PM
84 Ram's Avatar
84 Ram
Default RE: need long wheel studs
I have put alot of aluminum wheels on alot of different vehicles. I have never had to change the studs except on my 68 Dartdrag car and that was because the rules state that you have to. Do you have the right lug nuts for the wheels? I may be wrong but, if you have the right lug nuts then the wheels should work with your studs.
Old Sep 27, 2007 | 03:07 AM
Nofrag's Avatar
Nofrag
ORIGINAL: 84 Ram
I believe he wants to use wheels from the current generation Ram, on his 92. The offset is different, and you need spacers and longer studs to use them. I only know this because I was looking into SRT-10 Ram wheels because they are all over ebay for decent prices. Best looking 22" wheels you'll ever find for a grand a set if you ask me.
Tim, what you want to do is ask at a local wheel shop. If they don't have them, they'll sure as hell know who does.
