ULTAMATE D150
I like your front bumper how did you you get that winch in there that would be cool on my w 250
well igot the idea from a ram charger i sawon the coverfour wheel magazine. i got a piece of 1/4 in steel plateand mounted a mile marker 8000 on it. and then bolted that steel plate on that cross frame section right behind the bumper. part of the plate rests on the body section that sits on the crossmember but i works great for me. and the fairyhead im sure you can figure out. i just cut my bumper. i cant tell you how good it is to have a winch on a 2wd. no more 2 hour stucks! The front coil overs are off a 93 1 ton with 2 inch daystarspacers. the 1 tons gave me .5 -1 inch lift. not to bad for 25 bucks. oh and my bumper isspaced out with 4 washers on each bolt that hold the bumper on. thats important!
cant you just go to like four wheel parts or somewhere and check out some lift coils that would work for the weight of your truck? maybe just change over thespring mountson your axle and get different coil buckets... idk man just a suggestion. yai put 5 inch lift springs in the rear of my bitch, which eliminates the block andgives a three inch lift, all while riding like an unloading dumptruck,so i know what youre talkin about withstiff ride... gonna take another leaf out and fix my exhaust (its cut right after the muffler, blows right on the shock) so i can put new gas-charged shocks on. then maybe a locker? what kind of locker are you running and how much was it? dont even say "lincoln locker"...
