2X4 to 4X4 help
RE: 2X4 to 4X4 help
Oh it can be done if you can gather the parts you need. It will take some creative skills, and a working knowledge of building with metal. There is a lot to say so if you want, send me a PM and I will get your contact info from you and give you a shout. I am working 5 (12 hr) days and 10 on sat. for the next two weeks, just tell me when the best time to call you is and I will as soon as I can.
Are you going for about stock height or are you planning on lifting it, what size tires do you plan to run?
Your big ticket items are:
1. a Dana 60 front, don't even mess with a weak dana 44!! Been there done that!!
2. a 4x4 tranny or you could find a divorced 205 t-case from an older model dodge
3. 1/4" thick plating, maybe a 36" piece of 4"x6" tubing,
4. if the front gears don't match the rear end, you will need a set of gears.
5. You will need a set of front 1-Ton leaf springs. (since you have the diesel engine)
6. a 4x4 steering box possibly, and draglink.
The best thing would be to have a friend that has a 4x4 Dodge truck around your year model (they are about all the same though) and use it to go by while you are building/converting yours. Then you can see how things need to be laid out!!
