tired if v6 problems now its time for a hotrod
Old Jan 15, 2008 | 11:17 AM
300hp318's Avatar
300hp318
Default tired if v6 problems now its time for a hotrod
i have replaced the o2 sensor and the map sensor along with all the vacum line and my 89 didge d100 v6 5spd. still doesnt have any power past half throttle, and will not pull 4500 rpm in neutral, so i am going to put my 300 hp 318 in it. What will be the hardest part of this swap. Motor mounts have to be relocated? new radiator?
thanks for the help
Old Jan 15, 2008 | 11:51 AM
Maui_808's Avatar
Maui_808
Default RE: tired if v6 problems now its time for a hotrod
it will all be hard, just get a couple friends to help you out, you should probably be able to do it in a day or 2.
Old Jan 15, 2008 | 11:57 AM
300hp318's Avatar
300hp318
the motor bolt right up to the transmission right? And all the wiring is almost identical right? my man problem will be motor mounts?
thanks
Old Sep 24, 2008 | 02:39 PM
hebbyg's Avatar
hebbyg
try getting rid of your cat convertor man....it sounds like that might be your beef.
Old Sep 24, 2008 | 05:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I agree! Have you had the cat checked? Remove the 02 sensor and see if it runs any better.
