magnum 318 in a 77 W200
Old Feb 18, 2008 | 09:19 PM
77dodgetuff's Avatar
77dodgetuff
Default magnum 318 in a 77 W200
I have a 77 W200 4x4. Ive put a 95 magnum 318 in it. My problem or question is will the heads off the original 318 fit on the magnum block to accept the original intake manifold? Or if anyone close to my location has a mid 90s 4x4 pickup for sale with no motor or something to that effect thats relatively cheap. Preferably a regular cab long bed. Any info will help alot.
[/align]
Old Feb 18, 2008 | 10:46 PM
nemesis_SS's Avatar
nemesis_SS
Default RE: magnum 318 in a 77 W200
i know that on the later LA engines the magnum headers must be modified to fit. i figure then that it should work in the oposite direction on yours....
Old Feb 18, 2008 | 11:04 PM
lugnuts's Avatar
lugnuts
The Magnum oils through the pushrods, the non Magnum through the oil passage off the #4 cam brg. Don't thinkthe Magnum block is drilled.
Old Feb 19, 2008 | 12:45 PM
moparborn's Avatar
moparborn
Keep the magnum heads,they are better,Summit sells a carb. manifold for that motor.
