rocker panels
Old Mar 10, 2008 | 03:31 PM
2young2drive's Avatar
2young2drive
Junior Member
Default rocker panels
hey i have a 92 extended cab and i need some replacement rocker panels for both side. does anyone know where or if they have replacements for an extended cab? and also does anyone know of some headers that work for the 92 magnum?
Old Mar 10, 2008 | 04:10 PM
turbododgepirate's Avatar
turbododgepirate
Default RE: rocker panels
No idea about rocker panels. I have heard (Can't verify) that the regular 318 headers also work on the 318 magnum.
Old Mar 10, 2008 | 06:51 PM
nemesis_SS's Avatar
nemesis_SS
unfrtunately, that aint gonna be easy to find
i hope your good with tin snips, sheet metal, die grinder, and a welder
or,
what you could do is get some 20 or 22 gauge steel, (from a steel wholesaler NOT your local store they rip you off). Then you know where the body panels have a break/bevel on them? Starting from there start shaping the sheet metal down to the bottom with snips and a rubber mallet. you can rivet it in and cover with bondo. You can paint it, or you can use a super heavy black undercoating (which is what id do - youll never have to worry ever again). Go to a wrecker, rip off the outer trim of any vehicle you like (or buy new, as long as you get enough - measure first) and then glue the trim down right along the beveled area where your new steel meets the old.
plenty of people have done this, and its done in a couple afternoons, and whatever they charge you fo new rkcer panels - if they exist - this will be cheapep
Old Mar 11, 2008 | 04:18 PM
2young2drive
Junior Member
wow thanks for the info. i guess making it myself sounds like the way to go. outside of finding a truck with clean rocker panels, which is unlikely around here, oh well thanks.
Old Mar 11, 2008 | 04:39 PM
nemesis_SS's Avatar
nemesis_SS
even if you find a truck with clean rocker panals....how are you gonna get them from one truck to the next?
Old Mar 11, 2008 | 05:41 PM
2young2drive
Junior Member
cut and weld
Old Mar 12, 2008 | 01:12 PM
BIG HOOK's Avatar
BIG HOOK
autobodyspecialties.com may have what you are looking for.
Old Mar 12, 2008 | 03:40 PM
PushnFords's Avatar
PushnFords
ORIGINAL: BIG HOOK
Actually it is http://www.autobodyspecialt.com/
Good timing. I'm picking up a parts truck over spring break that I'm told needs a rocker panel from being smashed. I guess it is a parts truck...I'm using the front clip, cab, and probably the engine. Maybe that makes my truck the parts truck?
Derek
Old Mar 12, 2008 | 09:11 PM
2young2drive
Junior Member
wow thank ou very much for that site! ill have to call them up and see if they make ext cab rockers
Old Mar 12, 2008 | 09:32 PM
84 Ram's Avatar
84 Ram
ORIGINAL: nemesis_SS
Drill the spot welds and remove it wherethe factory installed it. The rocker should come off just as it was put on.
