1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Light throttle 2-3 OK? Full throttle 1-2-3 shifts OK? Weak spring in govener most likely. Weak spring in valve body,or worn valvecan cause it too. You can chk kickdown. Should be all the way back at WOT.
Not much to do with it in the truck other than chk the kickdown linkage and adjust the bands. Pull the pan and look around,see if there's any clutch mat'l etc. If the kickdown's OK and the pan's reasonably clean, I'd just stick another trans in it,or have it rebuilt. Without driving the truck myself,educated guesses are the best I can do. Since reverse is OK, the low/reverse band is holding,you'd still have first,just no engine braking in manual low,no reverse.
What's it do when low is manually selected?
well i cleaned the big connector that goes on the computer, and all the grounds i saw, their where two wires that came from the battery term.that where about to come from their lugs that somone repaired ... i fix them, so far it working well and not duying...
