91 ram 360 tbi,cking tps,02,and pick up coil?
Old Apr 9, 2008 | 08:11 AM
flathead31coupe's Avatar
flathead31coupe
Default 91 ram 360 tbi,cking tps,02,and pick up coil?
can you ck any of these... and if they go bad do they always throw a code....
Old Apr 9, 2008 | 01:41 PM
nemesis_SS's Avatar
nemesis_SS
Default RE: 91 ram 360 tbi,cking tps,02,and pick up coil?
check O2 sensor, which is supposed to give a check engine light. (Haines has isntructions. But basically, put positive voltmeter probe on green/black, negative on a cleanground. Itshould read steadily between.1 to.2 volts runningcold. after a couple of minutes when the thermostat kicks in at temperature, you should start to read fluctuation between .1 and .9 volts. if this doesnt happen after 3-4 minutes, shes fried)
i copied this from another thread
TBI is probobaly fine, I dont hear of them braking. Pick-up coils can wear out. they probably wont throw a code, and theyre cheap to replace.
