It RUNS!!!! Well, sorta.
Old Apr 18, 2008 | 09:11 AM
turbododgepirate's Avatar
turbododgepirate
Default It RUNS!!!! Well, sorta.
Well, Trailerd my 1985 D100 home a few months ago, and with wonderful PA weather, it has been sitting in my yard. I pulled out the carpet on a nice day to find the floorboards pretty rusty. Pulled the radio and put in a CD player, and did a few minor things.
The truck hasn't run any farther than on the trailer to get it home, and about 50 feet in the driveway. All at fast idle. Well, I dumped 5 gallons of fresh gas in, and started it up the other day. But soon niticed a gas smell, popped the hood and sure enough, a fuel line was spraying everywhere. Shut it off only slightly aggrivated. Yesterday I got the proper fuel lines, a new filter, and new clamps, and put it all together. It fired right up like a champ. There is some squeeling at fast idle that goes away at regular idle. But for some reason it kept stalling out in regular idle. After I had it running for about 5 min, it nearly stopped doing that. It ran enough to move around the farm a little more. Brakes feel super stiff. The booster is rusty and corroded as can be. So I suppose it could be rusty front rotors, and possibly rear cylinders, and even the booster as well. The truck has sat at least 4 years.
Oh well, at least it runs and moves under its own power.
Old Apr 18, 2008 | 07:48 PM
nemesis_SS's Avatar
nemesis_SS
Default RE: It RUNS!!!! Well, sorta.
you certainly are on the way to the stars on the wings of a pig
Old Apr 20, 2008 | 08:18 AM
racer9's Avatar
racer9
Try a little Lucas or Howes fuel injector cleaner. It should clean out that fuel system pretty good.
Old Apr 21, 2008 | 11:20 AM
turbododgepirate
ORIGINAL: nemesis_SS
Hahahaha How long did it take you to look that up?
Old Apr 21, 2008 | 11:21 AM
turbododgepirate
ORIGINAL: racer9
Is that a good idea even though it is carbed?
Old Apr 21, 2008 | 04:02 PM
racer9's Avatar
racer9
It worked good in my carb'd motorcycle.
