GRILLS
Old May 2, 2008 | 09:05 PM
Fnix's Avatar
Fnix
Default GRILLS
Where can I view different Grills selections for an 1987 d-150?
Old May 4, 2008 | 10:56 PM
driveramsII's Avatar
driveramsII
Default RE: GRILLS
Only one grill style for the 87 that im aware of. With that being said, you can put the 91-93 grille on it or the earlier models but the pre-81 had different headlights.
Old May 5, 2008 | 09:31 AM
turbododgepirate's Avatar
turbododgepirate
Default RE: GRILLS
Well, with the 91-93 grille you really should replace the core support as well, otherwise you will have to chop up and modify the existing core support (Probably more work than it is worth)
I was looking at other grilles this weekend. I have the waffle like 1985 Grille and want a crosshair grille. But it looks like the grille surround varies from year to year.
I also found a local truck with a quad headlight setup ala little red express that I might try to coonsnagle from the guy.
Old May 5, 2008 | 10:53 PM
moparborn's Avatar
moparborn
Default RE: GRILLS
I believe the 81-85 are the same(waffle style)and 86-90 are the same(cross hair).
Old May 5, 2008 | 10:59 PM
driveramsII
Default RE: GRILLS
You would be correct. The grill surrounds are slightly different between the 81-90 but can be made to work. The pre 81 have different core supports because of different headlights
Old Aug 2, 2008 | 03:20 AM
grimmey71's Avatar
grimmey71
Junior Member
Default RE: GRILLS
I am looking for a 79 four head light grill if anyone has any sugesstions
