used carb looking rough (pics)
Here's a shot of the baseplate on the '86 Q-jet I just received. It looks like someone tried prying it off with a screwdriver.
[IMG]local://upfiles/72844/861CB4AA698F404BB23CB0EA0750835C.jpg[/IMG]
[IMG]local://upfiles/72844/90C3399257D042A8A3AF0AC737A3C221.jpg[/IMG]
Mighta got something chunked on it. A little careful flat filing should clean it up. While it aint pretty,given the area it's in it shouldn't be a problem. Does it have anmeter controlsolenoid in it or other computer garbage?
ORIGINAL: lugnuts
I'll give the junkyard a call tomorrow and see if they have another baseplate to send.
Mike if memory serves the U shaped one is the ported vacuum circuit,see if it ties to a nipple on the front of the carb. Should be a couple holes just above the blades.The j shaped is straight vac. ports? Been a while since I've done a Q-jet. You think the gouges are too deep? Those Q-jet gskts are pretty thick an' squishy.
On a side note there's a brass stop screw that adjusts the primary metering pin piston. The piston/metering pin assy.has a pin that rests against it. Vacuum pulls the piston pin against the stop screw,opposing a spring. It sets the depth of the metering pins in the jets. It's best not to jack with it. I have raised the pins a littleto help a lean surge @ cruise,but mostly I don't touch it.
I blew some air in but cant tell where it's going. Might have to get the thing apart first. The deepest gouge is about .025".
I'll try not to unscrew anything I dont need to.
ORIGINAL: nemesis_SS
try gooping a bit of JB weld into the gouges and then filing it flush
Trending Topics
it would **** me off to have recieved the carb beat up like that but i guess buying it used and unseeni would just get over it and move on with a rebuild.as long as it doesnt suck air from those gashes i wouldnt worry about them.if you do aresurface it may throw off the flange adjustments.....just my opinion im not a carb tech even though i play one at home
I always liked the Q-jets OK. Kinda touchy on choke settings,but otherwise pretty dependable. Not too prone to heat soak induced flooding etc. like the
2bbl Autolite Fords were. Easy to change the secondary metering pins and air door adjustment.
