Electrical problems-please help ! -No reverse lights, No O/D & odometer not working
Old Jun 16, 2008 | 12:02 AM
ruralcarrier4x4's Avatar
ruralcarrier4x4
Default Electrical problems-please help ! -No reverse lights, No O/D & odometer not working
HELP- I have a 1990 Dodge Power Ram 250 4x4 with a 360 V8 and automatic with Overdrive Transmission. I just bought it, the Reverse lights don't work, the truck does not go into overdrive regardless of the O/D lockout button (But shifts great through all other gears)and the odometer isn't working. I bought another instrument cluster and swapped out mine for thee one I bought and the odometer still doesn't work (but speedometer does-on both)-Is there some type of switch or electric box of some kind that controls all this? When I replaced the cluster it was ALL electrical hookup- no cable for the odometer -That is why I wonder if there is a module Somewhere that controls all this that is burned out ? Please help- Thanks, Jim
Old Dec 27, 2008 | 04:55 PM
davidsclocks's Avatar
davidsclocks
Default Odometer not working
I have a 1990 Dodge Ram odometer isn't working. I bought another instrument cluster and swapped out mine and the odometer still doesn't work (but speedometer does-on both)-Is there some type of switch or electric box of some kind that controls all this? When I replaced the cluster it was ALL electrical hookup- no cable for the odometer -That is why I wonder if there is a module Somewhere that controls all this that is burned out ? Please help- Thanks, David
David Brown
davidsclocks@peoplepc.com
501-821-3364
Old Dec 27, 2008 | 06:50 PM
dasaroth's Avatar
dasaroth
I might have an answer for both you guys, my friend had a 1990 w250 4x4 and he lost his odometer. come to find out it was his speed sensor located on the tail stock of the transmission.well anyway its a relatively cheap and easy place to start diagnosis.watch when you pull the sensor it may leak oil i usually just plug it with a rag or something handy.hope this helps
To test the Vehicle Speed Sensor:
  • Remove the Vehicle Speed Sensor from the transmission.
  • Connect an AC voltmeter set to the 0 to 1 volt scale to the connector pins (a) and (b)
  • Turn the Vehicle Speed Sensor pinion quickly with fingers and measure the voltage across pins (a) and (b). Reading should be approximately 0.5 volts AC.
Old Dec 28, 2008 | 07:55 AM
davidsclocks
Thank You very much,
I found a Speed Sensor at Auto Zone for $33.00. I really do appresate guys like you helping us poor fokes out.
davidsclocks
here is what I do
http://www.BibleBelieversRadio.com
