Ballast Resistor
Old Jun 24, 2008 | 06:05 PM
nemesis_SS's Avatar
nemesis_SS
Default Ballast Resistor
So im stil trying to figure out why my truck cuts out on the highway. Somebody mentioned that it might be the ballast resistor. So I looked, and even with help from Haynes, i couldnt find the damned thing. Ive got a 91, 318 TBI. Anybody able to give me a general area (back right or back left or something) or maybe even a picture?
Also, the voltage to my coil is 13 on one side - which is within the 1 volt of battery level suggested. But the negative terminal reads under 11, about 10.5-10.75. Any ideas?
Old Jun 24, 2008 | 09:09 PM
Comma's Avatar
Comma
Default RE: Ballast Resistor
On my truck the resistor is on the driver's side, to the right (looking at the grill) of the brake booster and ignition module. I circled it on the picture I attached. Also, the voltage sounds low to me, do a coil resistance test to see if it's ok. You should see around 10.5k ohms between the center and positive and around .7-.8ohms between positive and ground.
[IMG]local://upfiles/87633/1117EE1E5D72483B954C648F6D1477BE.jpg[/IMG]
Old Jun 24, 2008 | 09:51 PM
moparborn's Avatar
moparborn
You should not find one on that new of a truck.
You will need to troubleshoot when that happens(fuel,spark).
Old Jun 25, 2008 | 01:30 AM
nemesis_SS's Avatar
nemesis_SS
thanks comma thats where i figured it would be, and thanks moparborn for telling me why i didnt see it there...
im going to check the omhs and get back to you. this problem is really starting to get at me.
