Manual transmission swap
Old Jun 28, 2008 | 04:37 PM
Comma's Avatar
Comma
Default Manual transmission swap
Hello all,
I am getting really, really sick of my automatic. I know, I know, the 727 is a good tranny... but I can't stand it. Driving with an automatic is extremely boring to me, I hate the lack of control over my vehicle. Not to mention I feel the auto is a waste of money (I can feel the money flowing out of my wallet to be expelled as waste heat from my TC). I want to swap in a 4 speed from a junkyard 1st gen Dodge Truck I found recently, the truck is an I6, mine is a 318, so I know it'll have a different bellhousing, it's also a short wheel base truck unlike mine so I can't use the driveshaft. I will likely take the pedal assembly and all clutch parts that may be reused. I understand a lot of what needs to be done as I have good experience as a mechanic, but it's better to ask questions and learn from other people than do trial and error stuff.
So now I ask, from those who have done it or seen it done:
What will I need to convert my extended cab ram into a manual? Are there better alternatives out there than the junkyard 4 speed? (5 speed out of a newer ram, or an easier to find ford or chevy?).
Thanks in advance for any info
Old Jun 29, 2008 | 11:25 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: Manual transmission swap
Biggest problem you face is that the crankshaft typically isn't drilled for a pilot bushing if the engine was mated to an automatic. There's only one way to find out if yours was.
Other than that, it's a pretty straight-forward conversion. Tranny, pedal assembly, bell crank and linkage.
Old Jun 29, 2008 | 06:49 PM
moparborn's Avatar
moparborn
A full manual valve body won't do?
Old Jun 30, 2008 | 02:53 PM
Comma's Avatar
Comma
No, not for me it won't. There's still no clutch and a TC sapping power and gas mileage.
