no back up lights
Old Jun 28, 2008 | 10:40 PM
power ram's Avatar
power ram
Default no back up lights
I have break lights but, no back up lights! I wired in a new nss harness, wire for wire so i know that is right. What else can i check for?
Old Jun 28, 2008 | 11:16 PM
moparborn's Avatar
moparborn
Default RE: no back up lights
Make sure the bulbs are good,you have a good ground and then use a test light and backtrack.
Old Jun 29, 2008 | 12:21 PM
power ram's Avatar
power ram
both bulbs are good, fuse is good. im guessing there should be a ground on the frame somewhere close to the tail lights?? I have never used a test light, I dont have one either. Is that just a bulb with two wires?
Old Jun 29, 2008 | 06:44 PM
moparborn's Avatar
moparborn
That will work,or a meter.
Old Jun 29, 2008 | 07:03 PM
power ram's Avatar
power ram
Like I said I havent checked tail light wires, how do I check them?
Old Jul 1, 2008 | 12:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What about a faulty back up light switch ?
Old Jul 1, 2008 | 08:25 PM
power ram's Avatar
power ram
where is that located?
Old Jul 2, 2008 | 07:00 AM
zman17's Avatar
zman17
I only know if its a manual tranny. It's up high where the shifter goes into the top of the trans, towards the back. On an automatic I dont remember, it's been too long.
Old Jul 4, 2008 | 06:34 AM
bpcarman's Avatar
bpcarman
if its an automatic the switch is on the drivers side near the shift linkage.it has a three prong plug.you can jump a wire across the plug and they should come on.if they do either the reverse light switch is bad or the linkage is out of adjustment.Both are easy to fix.
Old Jul 7, 2008 | 06:00 PM
zman17's Avatar
zman17
Get it working ?
