Exhaust help
Old Aug 14, 2008 | 03:09 PM
D_Lepinski's Avatar
D_Lepinski
Junior Member
Default Exhaust help
I cut the cat off and ran a straight pipe to a cherry bomb, the only problem is that the air line that comes off the manifold to the cat blows air and makes an annoying sound is there anything I can do to fix this?
Old Aug 14, 2008 | 06:36 PM
moparborn's Avatar
moparborn
Take two metal plates big enough to cover the rear ports on the exhaust manifolds,drill a bolt hole add some tex and put them in place of the plumbing,thats what I did.
Or you could use visegrips and close off the tube.
Old Aug 14, 2008 | 07:30 PM
D_Lepinski's Avatar
D_Lepinski
Junior Member
Thanks for the help. If I did just close it off is it possible for the pressure to blow it apart or anything?
Old Aug 14, 2008 | 10:19 PM
moparborn's Avatar
moparborn
No problem,not enough pressure.
