need help bad
Old Sep 16, 2008 | 08:25 PM
4438's Avatar
4438
Default need help bad
i have a 1989 3/4 ton dodge and alotta times the lights just shut off...and come back on when they are ready then do it over again i already changed the switch no luck the wires are hacked up can anyone give me a wire diagram
Old Sep 16, 2008 | 10:03 PM
moparborn's Avatar
moparborn
You changed the headlight on/off switch?
Try the dimmer hi/low switch.
Old Sep 16, 2008 | 10:08 PM
4438's Avatar
4438
i can try it but its almost def in the wires cause they have been hacked up so much
Old Sep 16, 2008 | 10:10 PM
moparborn's Avatar
moparborn
I had the same problem with mine,changing the dimmer worked for me.
Old Sep 17, 2008 | 01:28 AM
tbirdscott's Avatar
tbirdscott
The headights usually use an automatic circuit breaker instead of a fuse, as they get old and worn they will overheat and flip off, once they cool down it will connect for a while before getting warm and disconnecting again.
Scott
