bolted on the nos holley tbi- interesting
Old Nov 2, 2008 | 12:18 PM
power ram's Avatar
power ram
Talking bolted on the nos holley tbi- interesting
Bolted it on, and let it ran for a bout a min. and it so far theres not any popping noise from the muffler. Im goign to put more fuel in the tank and let it warm up and see what it does.
The one thing I find interesting is the map sensors. The nos sensor on the body had a male connector. The one I replaced had a female connector so I put the old sensor on the new body. Why are there two different pin connectors?? Should I replace the three pin male connector with a female so I can use the nos Sensor??
Old Nov 2, 2008 | 12:49 PM
power ram's Avatar
power ram
ok its warmed up, Still no popping from the muffler. I can actually hear the injectors working.
I put the vacuum gauge on and now its 17 psi. So it advanced one more psi.
But, theres a gas leak!!!!
On the right side in the back corner and theres a small amount the close to the a/c compressor on the manifold. I checked the fuel line theres not any fuel leaking from those lines. I dont see any wet areas on the base. I did rev the engine high a bunch of times with the air cleaner off.
Well I guess Ill order a tbi gasket kit from the dealer. I should have guessed nos gasket wouldnt hold.
