'85 drive line clunk
Old Nov 19, 2008 | 01:07 PM
BIG HOOK's Avatar
BIG HOOK
Originally Posted by nemesis_SS
thats a very good idea. mine leaks so im going to have it apart eventually. Do they sell a grease fitting that you can intall?
Just score a common nipple style grease fitting at Ace Hardware or Napa, Nemesis. Drill and tap the hole to the appropriate size, screw it in and away you go. Location wise, the fitting should be located closer to the yoke end, where the grease sits in the open cavity space after the end of the driveshaft spline inside the yoke shaft.
I wish I could upload a diagram but for some reason it says my picture allocation is full, which behooves me because I've barely uploaded maybe 5 or six jpegs since I joined the forum about a year ago.
Tim
Old Nov 19, 2008 | 03:41 PM
nemesis_SS's Avatar
nemesis_SS
its ok i think i understand. i just didnt realize you could buy a standard grease fitting with threads on one end like that. so simple, so smart.
Old Nov 19, 2008 | 04:44 PM
power ram's Avatar
power ram
Mine also makes a clunking sound I think mine might the reverse band. My uncle in law told me the same thing yall said already. In fact if I remember correctly my dad's 88' ram also made the same clunk.
Old Nov 25, 2008 | 02:43 AM
oldmopie's Avatar
oldmopie
Default drive train clunk response
check the fluid level in your transfer that was always my problem
Old Jan 11, 2009 | 02:50 PM
95_318SLT's Avatar
95_318SLT
Take the differential cover off and measure the backlash. I believe the backlash should be between 5 and 8 thousandths of an inch. From my experience the threaded adjusters dodge uses in their axles (instead of using shims) can move over time.
