I figured it out
Old Dec 27, 2008 | 09:19 PM
power ram's Avatar
power ram
I can get a new ome steel fuel line ready to go for $55
but, how hard is it to bend new 5/16 metal fuel line? Im not very good at bending lines.
Old Dec 27, 2008 | 11:14 PM
RedWing442's Avatar
RedWing442
Geez, $55!!! Just go with the rubber fuel injection line. I think Nemesis misunderstood and thought you were talking about steel line.
Old Dec 27, 2008 | 11:20 PM
RedWing442's Avatar
RedWing442
Like you said, unhook the line, cut out the bad spot, hook up the rubber line with a couple clamps and you should be good to go.
Old Dec 28, 2008 | 12:04 AM
power ram's Avatar
power ram
well being that this line runs parallel to the engine, wont it get too hot?
Old Dec 28, 2008 | 12:38 AM
RedWing442's Avatar
RedWing442
Where exactly is the line located? If it's by the TBI across the intake manifold, it will be safe. If it's by the exhast manifold then you should use steel.
Old Dec 28, 2008 | 12:44 AM
RedWing442's Avatar
RedWing442
I just re-read you're original post. It sounds to me like you're talking about the line across the intake manifold next to the valve cover, if I'm not mistaken. Heat should not be an issue in that area.
Old Dec 28, 2008 | 11:59 AM
power ram's Avatar
power ram
Well I will install it then. I need two high pressure clamps and not flaring those lines correct?
or could i mix up some jb weld and coat the crack?
Old Dec 29, 2008 | 02:20 PM
nemesis_SS's Avatar
nemesis_SS
its just a crack? i would probably just drop some JB weld on it. maybe even take a little piece of steel and put that on top of the glue with a hose clamp holding it all together.
Old Dec 30, 2008 | 05:03 PM
power ram's Avatar
power ram
well thinking it over and talking with my uncle..
Im going to make a new steel tube line. He said its better to just replace it. I dont wanna mess with gas or brake problems in the future.
