D-150 318 feels sluggish
Old Jan 4, 2009 | 12:06 AM
ieatglue's Avatar
ieatglue
Default D-150 318 feels sluggish
Hey, my brother bought a D150 as a winter beater. It's a great truck and I drive it from time to time. It's got only 114K km's (71K miles) on it. I noticed that when I floor it, it seems very sluggish. It's got a V8, so I was expecting a lot more from it. The speedo is slightly off and the reverse lights won't work. Could it just be the speed sensor located in the tranny? He doesn't want to spend any money on it anymore. I've already replaced his distributor cap, wires, plugs, did a coolant flush, tranny flush, oil change, valve cover gasket replacement, and an air filter, but the truck still feels slow. The truck has a true dual exhaust on it, so I cut off the cats to inspect them and they looks brand new, so they wouldn't be restricting any exhaust flow. Should I just try replacing the speed sensor and see what happens? I doubt it's carbon build up because the truck has low miles on it.
Old Jan 4, 2009 | 07:01 AM
csd4682's Avatar
csd4682
I just went through a similar situation, and replaced all the same things you did, plus some. You may want to check for a vacuum leak. Does it make a poping noise or does it just accelerate slowly? Mine ended up being the distributor, and I found a vacuum leak. The leak was in the air temp fitting thats in the air cleaner, goes from the air warmer on intake to the inside the cleaner, then from that fitting to the carb. I just capped off the hose that went to the carb, and did away with the whole air warmer. Also during my quest I went to rebuild the carb and found there was bits of charcoal in the float bowl. I did away with the charcoal canister bit as well. We dont have emmisions test where I live. Good luck! it took me a while, but I really like the truck, and bought it for the same reasons as your brother. Just wanted something to play around in.
Old Jan 4, 2009 | 01:10 PM
ieatglue's Avatar
ieatglue
I doubt there's a vacuum leak. There's no popping, it just accelerates REALLY slowly. My dad says it's because the engine's old, but it's a V8, it should have much more power IMO. I'll try cleaning out the carb. and intake manifold when it gets a bit warmer
Old Jan 5, 2009 | 01:01 AM
nemesis_SS's Avatar
nemesis_SS
dont worry, im sure youre truck is still faster than lugnuts and 1996ram318
Old Jan 5, 2009 | 04:41 AM
ieatglue's Avatar
ieatglue
I haven't been on the forum long enough to get that joke, but im sure it's pretty funny I'm a www.trailvoy.com guy
Old Jan 5, 2009 | 06:37 AM
lugnuts's Avatar
lugnuts
Drag ya backerds.
Old Jan 5, 2009 | 10:33 AM
1996Ram318's Avatar
1996Ram318
My truck aint supposed to be fast. But it makes alot of torque. Come on down to Texas and we`ll see who can back up all this s*** get thrown around in here.
Old Jan 5, 2009 | 03:02 PM
nemesis_SS's Avatar
nemesis_SS
you throw **** around in your truck?
Old Jan 5, 2009 | 05:43 PM
moparborn's Avatar
moparborn
Hmm,could explain the color.
Old Jan 5, 2009 | 11:27 PM
nemesis_SS's Avatar
nemesis_SS
and the smell
