mess of a transmission
Old Jan 15, 2009 | 08:06 PM
nemesis_SS's Avatar
nemesis_SS
Default mess of a transmission
so i mentioned a little back, i had my truck up on jacks for a couple of days, and in combinaiton with the slope of my driveway and worn out transmission seals, i leaked all the fluid out. Then, not yet knowing what had happened, i drove it for a week and half all the while wondering why its running like a complete bag and making a burning smell.
So anyhow now its leaking fluid at all times. I added some stop leak, but that only seems to have slowed the rate of leak. I suspect there are broken teeth since it grinds here and there. I dont mind a few rough edges, but i cant be adding a litre of oil every week. my question is this, should i try just changing the seals to stop it leaking, or is the damage likely so bad that im burning through fluid and it needs a rebuild?
Second, is dropping the pan and changing the seals just as easy as removing the bolts i see holding it on...
thnaks!
Old Jan 15, 2009 | 08:43 PM
1996Ram318's Avatar
1996Ram318
I don`t know what transmission you have, but I can sell you a cheap one from an old Ramcharger. I believe it has a 904 trans.
Old Jan 18, 2009 | 07:45 PM
nemesis_SS's Avatar
nemesis_SS
mines the 3 speed without OD. A727 i believe. id love to figure out a deal on a new transmission with you. but im in ontario, so be the time we do all sorts of transporting i couldn get it locally. thanks though.
Old Jan 18, 2009 | 08:49 PM
1996Ram318's Avatar
1996Ram318
The problem would be the shipping cost. I could drop it at a freight yard and have it shipped to your town, but it would probably cost several hundred dollars.
