gears
Old Feb 5, 2009 | 12:18 AM
Mad Mudder's Avatar
Mad Mudder
Default gears
Dose any one know how to find out what gears that in a front and rear diff? I have a 86 Power Ram and don't know what gears that i have.
Old Feb 5, 2009 | 09:21 PM
lugnuts's Avatar
lugnuts
Here's a calculator. Other than that you'll have to count the teeth, divide ring gear by the pinon= ratio. Edit: LOL. Forgot the obvious. See if there's a tag on the cover.
http://www.richmondgear.com/101032.html
Old Feb 5, 2009 | 11:46 PM
nemesis_SS's Avatar
nemesis_SS
put the rear on jackstands, spin the driveshaft, and have someone count how many times the wheels spin after one driveshaft rotation. i think you might have to mulktiply by 2
Old Feb 6, 2009 | 12:06 AM
Mad Mudder's Avatar
Mad Mudder
There is no tag on it
Old Feb 7, 2009 | 07:45 AM
83dodgeswb4x4's Avatar
83dodgeswb4x4
Nemesis is close, except you spin the wheel one revolution and count the number of times the drive shaft spins and you have an idea of your gearing.
Old Feb 7, 2009 | 10:46 PM
lugnuts's Avatar
lugnuts
Unless it's a limited slip the spider gears will screw up your revolutions. Get a buddy to help,mark both tires and turn both one revolution simultaneously. Everybody should own a tach,basic neccessity of life lol. Install one,check the RPMs @ 60mph,use the calculator. Or pull the cover and count the teeth. Gear oil probably needs changing anyhow.
Old Feb 8, 2009 | 06:06 PM
nemesis_SS's Avatar
nemesis_SS
i know mine does, because its been dripping all over my dads driveway. oops.
Old Feb 9, 2009 | 07:56 AM
Mad Mudder's Avatar
Mad Mudder
The only leak that I have is on the rear main seal.
