Motor Swap 1975 W100
Old Mar 16, 2009 | 11:43 PM
  #21
zachman1767's Avatar
zachman1767
Thanks man. I appreciate it. I think I need to get the right motor mounts that bolt on the side of the block. If you know of where I can get some used please let me know. Bouchillons wants 70 bucks a piece for them, and I'll just weld and drill the ones I have for that much money. I think theres some on ebay for a 1972 truck, which I think is the same. There at 25 bucks right now so I'm lookin at those, but the faster and cheaper the better. Once I get the truck running ill post some pictures.
Zach
Old Apr 17, 2009 | 12:08 AM
  #22
zachman1767
Hey guys,
I am having some electrical issues with the electronic ignition on my 1975 dodge w100. It had a fuel injected 318 that someone put in it, but it was blown up. So I bought a Mopar 400 that was in a dodge pickup and dropped it in my 75. I wanted to use the electronic ignition which uses the 5 wire ECU and the dual ballast resistor. I wired up the ignition the way that the diagram I had showed, but when i try to start the truck theres only 9 volts at the coil. When its in the run position theres only 3 volts.
Could anyone tell me what the resistances on the ballast resistor are supossed to be?
Also, why did dodge install the dual ballast resistors on the electronic ignition models, i thought they were for points only so you don't burn them up when the truck is running.
Also if anyone knows how I should wire up the alternator and voltage regulator that would help me out alot too.
Any and all information will be helpful.
Thanks Guys.
Zach
Old Apr 17, 2009 | 12:10 AM
  #23
zachman1767
Question Carberator for 400
Also,
Does anyone know what size carberator will work well on a dodge 400? It has a carter on it right now with vacuum secondaries but i dont know the size and im thinking about getting a new one.
Thanks
Zach
Old Apr 17, 2009 | 05:34 PM
  #24
SEAL's Avatar
SEAL
The ballast resistor is there to save the coil according to the Motors manual. It didn't list the resistance but said if a problem was suspected replace the resistor. Sorry but that is all I can tell you.
Old Apr 17, 2009 | 09:00 PM
  #25
rtaylor's Avatar
rtaylor
the 400 engines came with carter thermoquads, they were rated at 800-850cfm due to the large secondaries, a 750 cfm eldebrock would work very well on a stock 400....
Old Apr 19, 2009 | 01:43 PM
  #26
rtaylor's Avatar
rtaylor
go with a eldebrock elec choke...........good carbs
Old Apr 19, 2009 | 09:38 PM
  #27
Mad Mudder's Avatar
Mad Mudder
Why not a good old Hollie?
Old Jul 7, 2009 | 07:30 PM
  #28
zachman1767
Thank you!
Does anyone know where the drain plug is located on a NP-203 transfer case? I cannot seem to find it anywhere and I'd like to change the oil in it.
Old Jul 13, 2009 | 06:20 AM
  #29
nemesis_SS's Avatar
nemesis_SS
did you solve the voltage problem? like SEAL says they resistors drops the voltage once the car is running. i figure it should be more like 12 at start and 6 when running. could be wrong. another things is if the coil has a built in ballast resistor it might mess things up
Old Jul 19, 2009 | 03:08 PM
  #30
zachman1767
Default Ecu
Do I need the ballast resistor if I have an accel super stock coil? I have the ECU hooked up and it was working, but now all of a sudden I have no spark. I wonder if I was supossed to hook up the dual ballast resistor to limit the voltage to the ECU. Do you guys know anything about this. Could I have fried my ECU or distributor?
Thanks,
Zach
