battery cable question
Old Mar 17, 2009 | 03:48 PM
tooltime's Avatar
tooltime
Default battery cable question
iIhave a 86 d150 with a 318.about a month ago i had to get a new battery.Last week i had to get new terminals.I just looked at the battery today and i saw from the positive post had a run on top of the battery.Why is that happening?Do i need new cables if so does anyone know how long i need thanks
Old Mar 18, 2009 | 12:36 AM
mohadib's Avatar
mohadib
a run? is that a crack in the insulation?
dib
Old Mar 19, 2009 | 01:17 PM
tooltime's Avatar
tooltime
sorry i meant to say that i have acid on the battery.Looks like it is below the bolt that tightens the cable on.
Old Mar 19, 2009 | 06:43 PM
doodlebug's Avatar
doodlebug
Clean your terminals and measure your old cables.
Old Mar 23, 2009 | 01:52 AM
83dodgeswb4x4's Avatar
83dodgeswb4x4
by acid on the top of the battery do you mean corrosion, the white podery stuff, or do you mean liquid acid? First, if its only carrosion I would disconnect both cables and clean the top of the battery with baking soda and water, then clean the terminals. However sometimes during the process of tightening the olts on the terminals it is possible to break the seal around the terminals themselves and they will begin to leak. If this is the case you will want to keep a close eye on the battery and keep the acid cleaned off until such time as you can replace the battery. I have personally run such batteries for a rather long time before replacing. Depends on if you can remove the caps to refill them with distilled water.
Old Mar 23, 2009 | 06:44 PM
tooltime's Avatar
tooltime
i have a new battery and new termanals.after i got the battery and before the terminals i looked under the hood and i had a "small run of acid" on the battery of the positive post right under the bolt for the wire.i had to buy new terminals and it still has it but not as bad.it was about a 1 inch long and white.all af the wires that goes to the terminals to me dont look good.i hope to replace them when i can and i was hoping someone has and knew what size i needed.
