oil leak/ spew 86 w150 318
Old Mar 23, 2009 | 08:30 PM
lugnuts's Avatar
lugnuts
Glad you found it. Pretty common malady on early small blocks. If you can find 'em, I like the red or blue Felpro gaskets with the metal insert. Make sure the PCV isn't plugged up with carbon,[check under the carb too] and the breather is clean and clear.
