Gas Tank Replacement
Old Mar 24, 2009 | 01:01 AM
64type1's Avatar
64type1
Default Gas Tank Replacement
I hope someone can help me on this. I have wasted a fair amount of time looking for a metal replacement for my plastic gas tank in my 77' pickup. The plastic tank is cracked and has become brittle in the heat of the southwest. ... Suggestions? Thank you in advance.
Old Mar 27, 2009 | 10:21 PM
88dakv6's Avatar
88dakv6
You can easily fix the crack in the tank they sell and epoxy that is like $10 at any auto part store that will do the trick, as far as the brittleness goes your toast….
I wonder if a 80ish tank would fit, salvage yards usually have them an pretty cheap too, and if none of that works then you can use an aftermarket tank like the ones used on drag race cars
Old Mar 27, 2009 | 11:44 PM
nemesis_SS's Avatar
nemesis_SS
epoxy might work, or that stuff specially made to fix gas tanks. Its comes in a roll - the outside is brown and the inside black and you mush it all together...
